LOSING CUSTOM PROPS
LOSING CUSTOM PROPS
hello,
I've loaded sw2001 sp0 at home (per license agreement). When I take work home I'm losing custom props on some parts (not all). The text of the link is still in the prop box example: $PRP: "SW-Current Sheet" OF $PRP: "SW-Total Sheets" this text is still there, but it's like it's not reading it because the link $PRP: "SW-Current Sheet" OF $PRP: "SW-Total Sheets" shows up instead of "sheet 1 of 1".
I've eliminated the cd because I brought it back to work & copied it into a new directory to try it & it works.
at work: nt 4.0
sw2001 sp14
office 2000
at home I've got:
xp pro
sw2001 sp0
office 97 sr2
would it be because I only have sp0 loaded ( I found our copies of service packs & will load them tonight), or windows xp, or office 97? or a combination?
Thank You
at work: nt 4.0
sw2001 sp14
office 2000
at home I've got:
xp pro
sw2001 sp0
office 97 sr2
Thank You
RE: LOSING CUSTOM PROPS
Also are you using the same drawing templates at home and work?
has anyone else run into this before?
thanks
