When using metric units, what constant do you use instead of 1.08?
I'm updating some calcs to metric units and for the equation Q=1.08*cfm*delta T, and I don't have access to any air density and specific heat values in metric units.  Can someone help me out?
RE: When using metric units, what constant do you use instead of 1.08?
Q(W) = 1.23 x V(L/s) x dT (K) at sea level.
[link]Air Properties[/link]
Density of air is reciprocal of specific volume, which you can easily get from a psychro chart.
a real anal point is that specific volume tells you the volume of moist air, that holds a unit mass of dry air, plus a small mass of water vapour.
Take the "V" out of HVAC and you are left with a HAC(k) job.
another question referring to using degrees celsius....
When using bin data in degrees C, is there a standard way to evenly space out the temps? (e.g w/bin data for deg F, there are usually 2.5-5 deg between each temperature)
