Save/Recall Selection Set
As a continuation of thought from thread559-206248: Macro to do surface area calculation, I thought it might be handy to be able to save and recall selection sets in a more general sense. The macro posted in that thread was specialized for faces and surface area. This macro is more generalized, and works on faces, edges, vertices, and planes. You can save and recall selection sets with any or all of these entities.
RE: Save/Recall Selection Set
Under "Reselect", hitting "New" will clear any current selections in the graphics area prior to selecting all the "saved" entities. Hitting "Add" will leave any current selections selected and select all the "saved" entities.
As a usage example, if the OP in the other thread were to use this macro instead of the one posted there, he would select the faces of interest from the graphics area and hit "New" under "Edit Set". Then, he could make any changes he wanted to the model, rebuild, and hit "New" under "Reselect". The faces of interest would then be selected (and the count of any missing faces would be updated), and he could activate the standard SW measure tool to get the surface area. If his modifications added a face of interest, he could select just that face and hit "Add" under "Edit Set". That way any "Missing" faces are retained in the bookmarked set so that if they reappear they will still be counted.
Hope that's a little clearer than mud...
