11 story building
11 story building
Hello all,
Can any of you guide me into geotechnical parameters I need to be testing for in regarding to the following:
Information for seismic considerations in regard to SLOPE INSTABILITY, LIQUEFACTION, AND SURFACE RUPTURE DUE TO FAULTING OR LATERAL SPREADING. I found a software for the liquefaction analysis (LiqIT), but I do not know how accurate it is. Has anyone used it in the past? If so do you have any recommendations that you can provide for interpretating the computed data? my building is 11 stories, and column loads are in the range of 4000 kips (3300 kips dead load). Any information that you have in regard to seismic design will be appreciated.
thank you
thank you
RE: 11 story building
