Enercalc Asce 7-02 Seismic Forces Q
I use Enercalc but am unsure about some calcs.  I want to replace my current methed of determining a BASE SHEAR REDUCTION FACTOR.  By using Enercalc’s “ASCE 7-02 Seismic Forces” tab; I am unsure what the R-Max-x ration value is in the sub-tab of “Reliability Factor”  and unsure of the Table to Bldg Weights under Base Shear & Vert. Distrib. Would the table include floor, partition, roof loads?  LL, DD?
RE: Enercalc Asce 7-02 Seismic Forces Q
The ASCE 7 explains it pretty well.  Have you tried that first?
