Horizontal Dimension Text Position
Using AutoCAD 2008
I have a dimension where the text is horizontal, I want the text to show top-left but I can only set it to bottom-left or top-right, is there a setting I can apply to allow me to position the text as I want?
RE: Horizontal Dimension Text Position
The easiest way would be just to explode the dimension then move the text. You can position the text in multiline text editor also.
