Gears to use for education / visualization
I am working for a truck manufacturer so we make big gears. Big gears that are not good to have on you desk and play around with. So, I am looking for gears that you can easy hold in your hand when you want to show and explain gears to somebody or if you yourself are thinking about how things are actually moving around relative to each other.
I have cut up the gear set of two angle grinders that I had and burned up. Luckely one of them had straight teeth and the other had spiral teeth. Both were bevel gears (no offset).
So now I am looking for something that has a small hypoid in them. Are the cardan drive of a motorcycle a hypoid?
I am also looking for something that has a planetary gear in it. Does anyone have an ide for that?
RE: Gears to use for education / visualization
http://www.sdp-si.com/
