Seal-weld a plug onto the tube.
Like to know the reason a plug has to be seal-welded to the tube of a heat exchanger.
It just so happens in the plant I am working, when a Turnaround take place, all heat exchangers with tube seal-welded to tubesheet has to have the plugs seal-welded to the tubes as well.
Thank you.
Thank you.
RE: Seal-weld a plug onto the tube.
