Electronic component identification
I have come across a faulty component that needs to be replaced but I can't identify what it is and thus where I can buy it from. It is disc shaped with 2 pins and on top it writes 'K391 J8'. Any help is appreciated.
RE: Electronic component identification
It's probably a 390uF ceramic capacitor.  Voltage?
Keith Cress
The 'J' likely indicates 5% tolerance. Not sure what the '8' signifies.
To correct itsmoked - its probably a 390 pF capacitor.
Otherwise it would be quite a hunk of ceramic!
Always gotta watch those uF, nF and pF Keith! I know what you meant to type!
I'm struck by the term faulty and can't imagine the probability of a 390 pF cap failing.   How many leads, 3?  Could this be a 2SK391?
Yeah! I figger out 390pF then write down uF.. ??
I rarely use any ceramics less than 0.01microfarads so I guess it's just finger muscle memory.
I would agree a 390pF cap is probably one of the most reliable components you'll ever come across.
Keith Cress
BTW: I do use some 10uF ceramics on a regular basis.  They're small SMT parts no less.
Keith Cress
Scotty,
Normally I would agree with you on the 5% thing, but the fact that the J is combined with an 8 makes me wonder if it's not a different type of code rather than tolerance.  If the component isn't a cap, that would be likely...
Dan - Owner
http://www.Hi-TecDesigns.com
Hi macgyver,
The 'K' could be a 10% tolerance code too, but it is in a strange place. I wonder if we'll get a photo of this mystery component?
I think that 390 Volts VDR,
390V varistor?
could very well be a varistor, and the J8 the physical size range, or energy rating. If it is either red or blue this makes it even more likely.
How large is it and what color?  A 390pF ceramic would probably be quite small.
Hi
That is 390 VDC, VDR( voltage dependent resistor)in case of defective it must indicate short circuit, if its tested with multimeter as a resistor
After nearly three months and no photograph I think the OP has lost interest. We're all guessing, and the OP seemingly doesn't care any more.
Maybe he died while testing the part, following our misguiding tips :D
