Biomas combustion air/fuel ratio
In my calculations, and assuming that i have biomass with humidity of 40%, i've calculated the air/fuel ratio = 0,7 kgair/kgfuel.
Can anyone confirm this value as correct or approximate?
RE: Biomas combustion air/fuel ratio
Thanks fo rthe replies!
Sorry, but i'm searching for this value for boilers that burn biomass in wood chips version and not converted in butanol to burn in internal combustion engines.
dianad:
Just find the fuel composition on weight basis, know the stoichiometry and oxidant composition and as a result flame temperature, oxidant to fuel ratio and combustion products breakdown on weight and mole basis will be provided by the spreadsheet for you.
Gordan
http://engware.i-dentity.com
It is common to assume an amount of 0.7 lb air per 1000 Btu released. If the calorific value is 5000 Btu/lb, the air needed would be 3.5 lb/lb of fuel.
Thank you all!
25362,
So, what do you think i may use, your 3,5 lb/lb fuel or my 0,7 kg/kg fuel?
thanks
To dianad,
You asked for a rough figure. I don't know how you estimated the quantity of air needed. Follow Feric's advice. It seems your figure of 0.7 kg/kg fuel refers to oxygen, which converted to air becomes ~3.0 kg/kg fuel.
See, please, the air requirements for a fuel oil with a Pi=10,000 kcal/kg, one needs about 11 normal m3/kg, which is about 13.5 kg air/kg fuel, which would correspond to about 0.72 lb/1000 Btu.
Of course, fuel oil practically doesn't contain oxygen in its chemical composition.
You need to add excess air for a perfect combustion which in the case of refuse may be quite a %.
Here is a short table showing the amount of air in lb/1000 Btu liberated as needed for complete combustion:
methane                0.73
methyl alcohol        0.67
propane                0.73
benzene                0.74
glucose                 0.69
cellulose                0.68
I hope this message is of help.
