Meshing curved surfaces
Please can you help me mesh a hollow sphere (dia 2m, wall thickness 35mm). The component is a turbine hub, so there will be 3 cut outs for 3 turbine blades, as well as a flange iterface for the main shaft.
My current efforts have resulted in meshing errors, but I do not know why - what are the best techniques to use for meshing curved surfaces?
