PCB Help & General Circuit Design
Working on Devoloping a custom Device for the GP2x handheld.
It's uses are a wireless internet provider an SD storage device and have portable power. It Needs to act as a USB hub with these devices "plugged" in. (will be hardwired)
Heres what I need to know. SD to USB.... What do you need , IE.. controllers what else? Also can be purchased in small quantites at mouser or digikey.
RE: PCB Help & General Circuit Design
Do you have a specific question?  We're not here to put together a design for you... unless you intend to hire one of us.
Dan - Owner
http://www.Hi-TecDesigns.com
Agreed Dan.
Also you need the file system firmware.  SD's want to talk a certain way about the file structure.  It would be easiest to locate a package that lets you use SPI to talk to an SD controller that talks to the actual SD.  Then you can use any SD, and when plugged into a PC it can directly read and write the same files.
Keith Cress
Agreed. You will hardly find whole projects here for free.
Anyway, you may start with a USB controller, a CPU and your SD memory. Allegro has some SPI/USB converter ICs to pass USB traffic to CMOS levels.
For CPU, you might use any cheap PIC, some AVR/ATmel, ARM or something that suits better your design.
As said before with SD memories, you need some  firmware 'drivers' on CPU to drive it and deal with filesystem.
Gonzalo
You can do a USB to SD interface in a single PIC procesor, and yes it can be bought at digikey.
Course you will need some software.  But its out there...just need to look for it.
You may also try the FT232BM from FTDI, an USB-to-serial converter IC.  It could save you some code lines (USB driver) for your uC.
Good Luck!
Gonzalo
you'll need a usb peripheral controller, and software to implement the mass storage protocol. Luckily, most manufacturers build single solution chips. I use the 8051 Atmel devices. They also provide plenty of software examples for USB implementation.
You might want to consider the compact flash for speed reasons.
