Float valve for Dirty conditions???
I have a shallow pan type of tank that is open on the top. Water and salts from the shallow pan run to a collection pipe (2") and then down into an open top collection drum, where it is pumped out on level control. However sometimes the level control fails. Sad but true. The drum will over fill and spill nasty water all over the place. I need a float style overfill protection valve. The trouble is that none of the valves I have found yet will work with a dirty fluid. I don't want to use a float switch and a solenoid valve due to the location. The solution will pretty much have to be mechanical. Any suggestions on suppliers? Right now my best bet is a valve from www.morbros.com but it requires 5psi of inlet pressure that I don't have.
StoneCold
StoneCold
RE: Float valve for Dirty conditions???
On one application that was handling 15% to 20% solids, I had success with a bubbler type level transmitter and a pneumatic control loop. Original mechanical gizmo with a float and a chain linkage was not reliable.
I am not sure why the float switch / solenoid valve was not acceptable. If the issue is "sticking" of the float, consider a vibrating fork type high level switch. The vibrating fork device is easier to set-up and more robust than a Capacitance/RF unit.
If the issue is plugging of the solenoid (2" seems quite large), consider a a 3-way solenoid pilot operating a 2" air-operated ball valve.
StoneCold
