Zinc Plated 10.9 Fasteners
I'm looking for a source for zinc plated hex head 10.9 fasteners, (socket heads are not desireable) and having some difficulty finding suppliers.
I'm aware of potential issues with hydrogen embrittlement, but am under the impression that proper processing can eliminate this concern... Presumably something any reputable bolt manufacturer would do as a matter of course
Am I correct in my understanding of the embrittlement issue, and could anyone suggest a source for hex heads?
Thanks in advance
Thanks in advance
RE: Zinc Plated 10.9 Fasteners
I was able to find zinc plated 10.9 hex heads on Fastenal.com.
What quantity do you need? If it is small, then distributors like Fastenal or even McMaster-Carr stock these items. Buyer beware.
If you need large quantities, then you can work with a manufacturer directly. Large manufacturers include Acument, SPS, and Nucor.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
QQ-Z-325C Zinc coating, electrodeposited requires 75% of ultimate "notched" tensile strength of the material for at least 200 hours (4 times the 48 hour). Another option is 115% of the maximum designed load of the part for at least 200 hours.
SAE/USCAR-5 AVOIDANCE OF HYDROGEN EMBRITTLEMENT OF STEEL
and
SAE/USCAR-7 DEEMBRITTLEMENT VERIFICATION TEST
Cory
however thanks for the specs, much appreciated. I'll look into those.
