Arc flash study
Arc flash study
Can someone direct me to a clear explanation of the equations shown in Annex D of NFPA 70E? I have been trying to reconcile some calculations I did recently and am coming up with widely different answers.
RE: Arc flash study
RE: Arc flash study
RE: Arc flash study
RE: Arc flash study
Current limiting does work, and that is part of the reason why these equations are different. They assume that the device will operate, usually within a quarter of a cycle, and that the current will never reach the peak value, which is what you have input into the equation. So, to put it simply, there is less current, and less time, so less arc flash.
I don't know if you could reconcile the two sets of equations. They are based on different assumptions, but even more, they are based on different test data. Hopefully, the next round of testing through the NFPA/IEEE partnership will yield a physics based set of equations, and will put many of the current problems to rest.
