Diesel Fuel "Shelf" Life
How long can diesel fuel be expected to remain viable?
Our maintenance does some sampling, but what is the recommended tests?
This standby diesel generator tank contains 2000 gallons, and is kept full.
RE: Diesel Fuel "Shelf" Life
Orenda
I know that's not very helpful, but I thought it was interesting.
I'd bet my lunch the show was refering to the nuclear fuel tht powers the main engins and not the diesel that is on board for incidentials.
http://w
It doesn't talk specifically about re-fueling the fuel tanks (diesel and/or jet?), but I found where it said the reactor fuel should be good for 20 years without re-fueling.
On the show I watched I thought it said it didn't need to come in for any fuel in that 20 years, but you are probably right that they were only talking about the nuclear fuel since 3 million gallons is only 410 gal/day which doesn't seem like much when you're burning it in airplanes.
A question on the OP. How does the cost of running the generator compare to buying electricity? Would it be cost effective to just burn up the diesel once in a while to keep it fresh?
Do a search on this site for your information. The topic has been discussed in great detail over the last few years.
rmw
We use PRI-D in all our fuel tanks with excellent results. Our main reason is that the boat captains will not run the oldest fuel first and some fuel could be year old.
http://www.priproducts.com/default.htm
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
That is not to say you couldn't burn the stuff after 6 months to 1 year, simply that your pre-use filters may need frequent replacement, you may have excessive bios, dirt, water, etc. in there, or your engine performance may suffer. That's why its essential to match your storage system reqirements to the criticality of your intended use.
Since you are using it for a standby generator, I assume that you have some maintenance on the generator as well.
Run the generator once a month for eight hours to verify it is in top condition when needed.
Keep the tank full, this prevents getting to much moisture (condensing) in.
