Reverse Power 32-1& 32-2
Good Day Guys,
Simple question from me. What can caused reverse power to Turbine-Generator? Can anybody give some explanations.
Azril.
Azril.
RE: Reverse Power 32-1& 32-2
Reverse power - power is coming into the generator and driving it like a motor; instead of feeding power out to the system.
Causes: prime mover of generator (diesel engine, steam turbine,hydro-turbine) is not driving the generator - lesser drive steam in turbines; lesser water turning the hydro-turbine, or lesser fuel into diesel engine.
Good design/commissioning of our partners from turbine control
Regards.
Slava
32.2 is possible only in case of signal "Main Steam Valve Closed"
Regards.
Slava
I knew how reverse power concept at turbine-generator i.e instead of generator drive the turbine but turbine drive the generator. What i really want to know is how this reverse power can happen at turbine-generator? as slavag said : 'Main Steam Valve closed'. What is other caused?
Bill
"Why not the best?"
Jimmy Carter
A reverse power from other source can cause windings failure in the alternator if there is no safty device i.e. reverse power trip relay.
Hardeep
When a reverse power is applied to the turbine, the turbine's alternator will not become a motor as the phase angles of both sources may not be the same at that time. In that case heavy circulating current will damage the windins of the turbine's alternator.
Hardeep
2. Turbine Controls failing; operators ignoring annunciators; etc..
BTW, we always get turbine/generator trips when these things occur.
Two Burnt2x's points exactly explained last FAULT OF TWO 500MW units in our area.
First unit was off by boiler problem, second by operators mistakes.
I'm not so joke about our partners from turbine control, lot of reverse power trips from turbine control systems.
Once I found reason of reverse power trip( 25MW steam turbine) : one wire of voltage circuit was diconnected.
One of "good" example: 9 trips on one night, after retrofit of turbine control ( was fun ).
Regards.
Slava
A universal one is a unit trip due to suprvisory instruments on the turbine combining with failure of main breaker to open due to a protection failure or a tripping battery fault, etc. This is usually a very serious problem for the turbine.
I saw a small steam turbine that almost flew out of the building when the generator breaker was opened on a normal shutdown, but the main stop valve wasn't actually closed, although its limit switch thought it was. The insurance company bought them a new T-G.
It's also fairly common to see a reverse power trip right after synchronizing if the operator doesn't pick up some load soon enough. To protect the LP section of a steam turbine, the 32 device must be extremely sensitive and set to pick up at very low power levels compared to the normal forward power. When using the normal Generator CTs and PTs, this power level requires an extremely low setting and CT ratio and phase angle error become an issue.
DPC, remind very important point. I see in new turbine (w/o name), instead main steam valve limit switch some calculation of flow and data from several sensors, for my pinion not so good solution.
Against operators problem, we used " wait time" solution, block of reverse power protection for some time after CB close position.
High inertia of the big unit just kept the thing turning with just a little incoming power. The equivalent in-house load was the only forward power flow from that unit, hence no reverse power.
I can surprise you.
ABB REM543/5 made in Finland have 3 stage of underepower function,that possible config as low-forward and reverse power:
The primary application of the function block is the reverse power protection (Operation mode = reverse power) of the prime mover of a generator. The function is necessary for the following types of prime mover:
• steam turbines
• Francis and Kaplan hydro units
• gas turbines
• diesel motors
The function block can also be used for forward power monitoring (Operation mode = underpower). In case of parallel connected generators for example, the load of one generator may be so low that it is better to disconnect it and let the remaining generators feed the network.
And ABB Swiss series RE216/316, where possible add to relay
I don't know ten time power functions and free configurable each one for the:
• reverse power
• active power
• reactive power
• power direction
And new ABB SWeden REG670 relay with 4 stage of underpower functions.
Regards.
Slava
I don't read your post right.
Don't pay attention on the my previuos post.
Regards.
Slava
Problem is reverse power operated in this case. 50AE ( or dead generator, or other terms) must be operated before.
Regards.
Slava
32-2 typically emergency trip of generator breaker after predetermined time delay after sequential trip is enabled. I have seen around 30 sec however different sized machines should have different settings.
Base on my own working experience,the causes of reverse power in turbine generator can be attributed to:
1. improper position / incorrect polarity wiring of C.T
in the generator or generator sychronization
panel to reverse power relay( it happen in a
newly install generator or panel)
2.it can been experience if one of generator in
synchrization have a decrease voltage and frequency
discrepancy, which will resulted to the generator to
work like motor, also affect direction of flow
current in primary and secondary side of c.t and it
resulted to reverse power fault.
Rgd
DAPOTITI
I get that at times when commissioning diesel generator sets, and they are lightly loaded. One can speed up while adjusting governors and cause a reverse power trip (or reverse kVAR trip) on the other generator before the first reaches overspeed.
