Resistance to abrasion
The Client Specification requires that laboratory test of Resistance to Abrasion (the loss of weight that shall not exceed 10 mg/1000 turns) be applied to 3PE coating for 24'' pipline.
Is the above test a regular practice because it sounds strange to me? The pipeline is normal underground , nothing special.
Thanks!
RE: Resistance to abrasion
That's provided by the company that makes the coating itself.
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
Hi BigInch,
Thanks for your reply. My point is that is it a normal practice for manufacturer that applied the coating?
The usual practice is for the coating manufacturer to hold a few common test certificates showing compliance with some relavent abbrasion resistance specs or coating industry standards in his files.  The applicator will simply ask for a copy of the coating manufacturer's test certificate and forward that to the party requesting evidence of compliance.
