The Bajulaz engine
The Bajulaz engine
RE: The Bajulaz engine
The surface area is huge, the compression ratio is low, and the amount of pumping working is increased.  It is more complicated and expensive to produce.
Looks a bit like an IDI diesel.  Would like to see some plots of BSFC etc.
... and probably an exciting *short* life. Thermal losses through that valve will likely be enormous.
I see two additional crank revolutions and corresponding valve reactions for no additional power strokes.  To me this is a net loss of efficiency.  Adding heat to the intake air charge should also drop efficiency.
Franz
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I don’t see how they can get the listed efficiency when they exhaust the burnt gasses. The heat stored in the metal components is what will be available for expansion during the sixth power stroke.
I’m sure the high temperature valve and guide would have to be special in order to live 150,000 miles without increasing pollution levels as will be required in the upcoming regulations.
Ed Danzer
www.danzcoinc.com
www.dehyds.com
I wish the animation had more frames.
I see a regular intake and exhaust valve on the right.  That much I understand.
The unique part of the hardware is an annular air gap around the prechamber/remote chanber, with the connections between the cylinder and the annulus and between the cylinder and the chamber individually valved.
But I'm not understanding all of the valve timing/ injection timing and gas dynamics.
Mike Halloran
Pembroke Pines, FL, USA
Just as an addendum, I spent far too long thinking about this last night.
One other issue is that the dead space in the system is large, and the poppet valves will need further dead space in which to operate. This gives you permanent EGR.
Obviously power for a given bore stroke and rpm will at best be 2/3 that of a 4 stroke.
fmep will be higher by 50% as well.
My guess is that it would show better sfc at part load than a 4 stroke, if anywhere, but that at full load (ie 66%) it would not.
The valve life is the killer.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
