Incorporated insulation in concrete slabes
I realise the strength trade-off but I would like to build a concrete slab exposed roof dwelling but would like it to have the best insulation properties possible. I want it to span whole rooms using its internal reinforcement. Load-bearing walls and floor would be concrete also. Is there anything I can incorporate in the mix which will help?
RE: Incorporated insulation in concrete slabes
