Construction Joint
Construction Joint
Construction Joint
Folks,
This always puzzles me. What is the best way to place your stop boards for the construction joint in slabs / rafts etc.?
    * at the lowerst shear line, or
    * at the lowerst bending moment line
Appreciate your comments.
Clefcon
RE: Construction Joint
Minimum shear, thus near midspan,where the bending is developed by push-pull forces, and the compression side is loaded axially without much shear.
hokie66 is right - at points of lower shear.
between the two you have listed, I would say at the lowest shear.  I have an article about construction joints in elevated slabs that didn't say to place them at midspan (lowest shear).  I don't remember exactly what it said, but I will look for the article on Monday.
thanks all for replying.
Clefcon
