InRoads Survey Styles
Hi all,
I am working on setting up some styles through InRoads Survey 8.8. Im having trouble with the style manager editing my codes so that certain information will automatically work for the dtm and other information won't. Basically I took PADOTS .ini translatted it into .xin and now I need to be able to map the styles to work as breaklines or not in the dtm at all. Any tips or help is appreciated thanks.
Adam
RE: InRoads Survey Styles
You need to make the styles that you do not want in the DTM as DNC. Do not contour. This can be accomplished in the Survey Feature Table file on in the DTM, you can toggle on in the features under surface>feature properties and click on "exclude from triangulation"
