BS4500 (ISO 1101) Fit Question H8/p7
I have a very good article from the Copper Development Association regarding bronze bearing design.  They recommend a press fit of H8/p7.  For a 165.1mm (6.5in) nominal bearing OD I have calculated a hole limits of 165.163/165.1 and bearing limits of 165.183/165.143.  If you take the smallest bearing diameter and largest hole then you end up with a clearance fit and not a press fit which won't work for a press fit bearing.  Did I calculate the limits correctly or is there something not right in the guidelines from CDA?
These values are significantly different than the recommendation from a bearing supply catalog I have.
RE: BS4500 (ISO 1101) Fit Question H8/p7
Hi lancer
The figures for the fit you quote H8/p7 are correct.
What you have though is a transition fit which can either be
a clearence or interference.
What are the other figures you have and is it from the same bearing supplier that your getting your bearing from, if so I would go with those figures.
regards
desertfox
Thanks for checking my numbers.  The chart I have from Bunting stops at around 4.5 inches diameter, but I found a different chart from another supplier that shows 0.002 to 0.007 inch force fit for this size bearing.  I'm just going to run with that.
Hi lancer360
Is there any temperature involved with the assembly you might need to check stresses or whether you still have a intereference with a rise or fall in temp taking in to account housing material.
I think otherwise you are doing the right thing.
regards
desertfox
I didn't think the temperature range would be much of a problem, but I guess it depends on what you use for a starting temperature when the bearing is machined.  Our operating conditions are from -20C (-4F) to 45C (113F) for offshore equipment.  If I make an assumption on the high side of 30C for the starting temperature, then I won't lose the press fit until -34C if I use my minimum press fit numbers.  The high side won't be an issue since at 30C there is only a 15C temperature increase.
Does this should right?
i have a hole with limits 30.006/30.009 and a shaft of 29.990/20.992. I  have calculated this as a clearance hole but am stuck as to which tolerance it is equivalent to. PLease can you help
1. New question - probably should have been a new thread.
2. Find a table of ISO tolerances and see which one matches yours.
