Excel rates mm/min
Excel rates mm/min
Excel rates mm/min
Hello having trouble getting excel to see things my way.
I am trying to get an output of mm/min and excel if getting the time unit mixed up.
I have something that has taken over 24 hours to occure and when I divide the distance by the time I get the wrong number.
I'm also interested in formating a cell to show minutes greater than 60. So 1:20:00 to show as 80. I have seen something on the net about [mm]:ss but can't find that in the format options just [h]:mm:ss.
If this have already been asked/answered please provide a link.
Thanks.
RE: Excel rates mm/min
Excel's unit of time is the DAY.
That is, a numerical value of 1 = 1 day = 24 hours = 1440 minutes.
Thanks That makes a big difference.
Re. the second part of your question: if you go to Format/Cells.../Number/Custom, you can type [mm]:ss in the box under Type:
You don't have to select anything from the list, Excel allows you to come up with your own format, as long as you use its Number format coding.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
