TS Moment Connection
We have HSS20x8x3/8 member welded on top and bot with full penetration welds and approximately 75% of the webs(sides). Can this be considered a full moment connection?
RE: TS Moment Connection
YES IT IS STRONG AXIS BEDNING. I WILL MAKE SURE THEY ADD A 3" MIN. RETURN WELD ON THE VERTICAL
The philosophy that you are talking about can be reasonably applied to a W section as the majority of the section is in the flanges.
In this case, more than half of the tube area and a significant amount of the section modulus is in the walls, and should not be ignored.
Personally I would check the welds under a triangular stress distribution.
But at the very least, if you are going to assume that the welds to the flanges are taking all the bending stress, then you need to check that the flanges can take this stress on their own.
csd
As part of a moment frame, a 20X8X3/8 has the capacity to take a lot of moment. Check the webs.
Mike McCann
MMC Engineering
