Freezing point water under pressure.
I was just wondering...
What is the freezing point of water is at e.g. 2 bar?
Is there a lineair scale between pressure and temperature?
RE: Freezing point water under pressure.
See the phase diagram at http://e
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
p.s. I did make a google search. English isn't my natural language, hence I didn't find the right answer.
rmw
If you stick a tank of water outside (Northern Canada), one open to atmosphere and one under your indicated pressure, both would freeze due to thermal losses. At two bar, the temperature difference is probably neglegible. You may wish to use a chemistry book or thermodynamic reference just to be sure, and post your search results to this forum.
I do know that freezing temperature does change with fluid flow, i.e. rivers freeze much later than lakes or still bodies.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
http://www
http://en.wikipedia.org/wiki/Ice_skating
