Imperial, Single Ball Bearings, w/ seals
Does anyone have any recomendations for a good stock stianless steel imperial bearing with seals?  I use 3/8, 3/4, 1, and 1-1/4 ID's.
Dan
RE: Imperial, Single Ball Bearings, w/ seals
It depends on what you mean by 'good', and by 'stock'.
I normally call my bearing distributor and ask what he has in stock or can get within my time frame, and ask him to quote a price.  Then I look up the manufacturer's specs for what he has, and compare them to my needs.
Mike Halloran
Pembroke Pines, FL, USA
Good = Not Junk.  My speeds and loads are generally light.
Stock = Stock.  On the shelf.  Ready to ship.
Dan
Thanks Syd,
They've got an easy to search web site with stock listings as well!
You've been a big help,
Dan
