Reference to Solver in Excel 2007
Hi, everybody! I have an excel 2003 vba project referencing to SOLVER automation library that does not work in excel 2007. I am looking for the new library name and cannot find, any tips? Thank you!
RE: Reference to Solver in Excel 2007
I don't have Excel 2007. In earlier versions, Solver is an add-in that is not installed taking the "default" installation. You have to do a custom installation and check the Solver add-in.
Add a reference to solver.xlam (under program files/microsoft office/office12/library/solver) in the VB editor.  You should then be able to record solver sessions with the macro recorder.
I just recorded the following simple session:
CODE
Sub Macro2()
' Macro2 Macro
    SolverOk SetCell:="$B$4", MaxMinVal:=3, ValueOf:="0", ByChange:="$B$3"
    SolverSolve
    Range("B6").Select
End Sub
Also search the VBA help for solver.
The following link may also be helpful for running solver VBA in different versions of Excel:
http://peltiertech.com/Excel/SolverVBA.html
Doug Jenkins
Interactive Design Services
www.interactiveds.com.au
Doug,
thank you for your help!
Yakov
