Odd problem with PVG 32 valve
I have an odd problem with some PVG-valves with a PVEH module.
With only 0,5 x UDC as a signal voltage, being in according with the documentation for the valve, this will normally positioned the main spool in neutral.
But I have discovered some unintended travel of the spool, as again induce a motion of the component there are connected to the valve in this condition.
This failure is infrequent, but annoying.
Had anybody experienced anything like this?
PEHE
PEHE
RE: Odd problem with PVG 32 valve
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
