multi taper helix
multi taper helix
Similar to the addition of the variable pitch helix, has anyone ever done a variable or multiple tapered helix in one shot? Single tapers are easy but can I create a sweep, as in a thread, with a taper into a straight thread, and continue at some point later to taper out? Any plans for this feature?
RE: multi taper helix
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
htt
(Also check out the third tutorial.)
Sweep your outer surface with a guide to establish your tapers (or do a centerline loft for the same). Then sweep a line through the center that rotates while being swept. Follow the tutorial for the rest of the details--piece of cake.
Jeff Mowry
www.industrialdesignhaus.com
What did you dream? It's all right--we told you what to dream.
--Pink Floyd, Welcome to the Machine
Twisted Ring
