A question posed
A question posed
In discussion with others a question was raised.
On a calm day there are two identical trucks pulling identical trailers at a very high rate of speed. They are on the same road and the distance between the two is far enough to not affect each other. If one truck has a far greater mass than the other, is the air turbulence different from one to the other?
Also, if equal acceleration was experienced would the answer be the same?
RE: A question posed
Each truck is an exact duplicate of the other. All elevation or section views would look identical. A plan view would be identical. The same tires, mud flaps, the same everything.
Let's consider the turbulence at a distance if a motorcycle was passing the truck in the middle of the next lane. Don't take into account the motorcycle's velocity or acceleration. That would make it way too complicated. Just a distance of eight feet from the side of the truck. Let's include the total drag also, good point.
The turbulence experienced by the passer-by and the drag on the truck are both determined by:
* The shape of the vehicle (assumed same)
* The state and properties of the fluid through which it travels (assumed same)
* The velocity of the vehicle (assumed same)
I'm going to have to go with "the turbulence is the same, the drag is the same" but add that I don't mean that every individual molecule of air would approach the motorcycle in the exact same way in each case, just that the measurable characteristics of the flow around the vehicles would be very very similar.
I suppose that there might be some immeasurably small difference due to the influence of gravitational attraction between the truck and its surroundings, but considering that is probably less important than counting all of the smashed bees on the bumper and mirrors.
Why, what'd you think you'd hear?
Applying the same argument to the equation for the the force generated due to aerodynamic drag, there is again no mass term for the body. Since the mass of the body does not appear in the equation, the math says that bodies identical except for their mass in identical flows will experience identical aerodynamic drag forces.
What should change between the two are the EFFECTS of the turbulence and the drag. If the magnitude of the forces on both the bodies due to turbulence and drag are equal, then F=m*a shows that the lighter body will experience more acceleration due to the the turbulence and drag.
I seriously doubt that either of these possible differences would be noticeable to a motorcycle rider, whether at 8 feet or 8 inches.
5 minutes in the penalty box is acceptable for idiot sportscasters but not for engineering professionals.
How can speed mean anything other than velocity? Speed is distance per time, velocity. A reference to rates of speed is merely implicating different values of velocity. Come on now theTick. A high rate of speed is implicating a reference of velocity. A velocity of moving slow to a velocity of moving fast. I believe most everyone picked up on it. The only rate of speed that would be zero would be if there was no change in distance for a given amount of time. Here is a thought you might like, rate of interest. We all know what interest is but the rate is quanitfying the interest. Let me get back to the question posed.
The question comes from observations and a genuine interest to answer questions. We approached it using different equations. I did find a reference to a body moving through air, air with no wind, air not moving. It referred to the turbulence increasing relative to the velocity squared. Unassociated, the equation of F*d=1/2*m*(velocitysquared) is one that I remember from years ago to evaluate a force to stop a body over a defined distance. This equation has nothing to do with the question posed but is interesting. If the two trucks I was talking about all of a sudden lost their source of power propelling them the heavier one would travel further before coming to a stop. It's force was greater. We all understand that and it is not a part of the question posed.
This is just something I thought interesting. Have you ever stood along the side of a road(hopefully not because your bike ran out of gas), or maybe under an overpass while you're waiting out the rain before you get back on the road and notice differences in what you see? I cannot find any equation where mass would make a difference. I just thought I might ask.
http://en.wikipedia.org/wiki/Ballistic_coefficient
As with the others, if all other factors are equal I'd expect no observable difference in the aerodynamic effects soley due to the mass difference.
If they aceelerate at the same rate again aerodynamic effects will be the same assuming everything else equal.
KENAT, probably the least qualified checker you'll ever meet...
How many wind-tunnel experiments validate shapes that are carved from solid blocks that represent objects that are basically hollow in real life?
As an aside, during the '73 oil embargo, when 55 mph speed limits were first imposed, the truckers were whining that the measure saved no fuel compared to 65 but cost them a lot of time. One of my professors at Univ. of Illinois did a test and found that there was very little difference in the total drag (and fuel consumption) on a semi-truck at 55 and 65, seeming to verify the truckers' claims. (Remember this is pre-Anteater KenWorths, typical block-shaped Macks).
Shall we move this discussion to the Grammar forum?
Did you not notice the
Sometimes the humour here can be very subtle, other times it's like being hit over the head with a 2x4 or
However, consider this:
A truck moving through the air is likely to produce a net vertical lift (or downforce).
Since Lift and Drag are related, is it possible that there is a second-order effect?
I'm thinking not.
If I recall correctly, L/D is a function of angle of attack.
Since our case is a constant aoa the lift must be constant wrt drag, and thus must also be only a function of geometry, and not of mass.
It swerved trying to miss the lighter truck and ran over you.
Seek medical attention.
Now, let's get a little out there and depart from the equations and think about the real world. As these trucks are barreling down the highway, bearing down on you, some of the energy generated by their engines is going into overcoming the drag and setting up the turbulence. The energy put into the air sets it swirling and some of it has to push back against the truck. Think of vortex shedding and how it can destroy structures. Now, some of that energy is going to rock the truck and make it move against its suspension, dissipating some of it. It reasons that the lighter truck will tend to be able to rock more than the heavier truck due to differences in inertia, natural frequency, etc. Could it be that the lighter truck is able to dissipate more of the energy it put into the air via its suspension than the heavier truck is able to? Then, even though they generate the same forces when they fly down the highway, the heavier truck is unable to reabsorb as much of it, and releases more net energy into its surroundings (you) than the lighter truck can.
I got thinking about crumple zones and thought of this. It's what happens as the afternoon drags on. The mind wanders.
If you were talking about a pair of gliders, and you held angle-of-attack constant, then drag would be the same, lift would be the same, and one of the two planes would hit the ground much sooner than the other (guess which).
Let's imagine the trucks are stationary and the fluid (air) is flowing around them. Does the mass of the truck have an effect then? No.
As jistre has pointed out there may be some other effects that are possible. I'll add that the heavier truck would also flatten the tires a bit more, resulting in less ground clearance...again, probably not altering the turbulence enough to measure or observe.
At the same aoa, a heavier glider needs to generate more lift. It does this by flying faster than the lighter glider.
Or more correctly, the thrust for a glider is the component of the lift vector that is aligned with the flight path. At the same aoa the heavier glider has more thrust than the lighter glider, and thus goes faster (albeit with higher drag) at the same L/D.
That's why gliders have the capability of adding ballast.
It would be spectacular.
And the glider flies faster by falling faster, usually by increasing aoa. No free lunch for gliders.
The advantage comes when you leave the idealized world of "still air", and start flying in air with vertical currents.
By flying faster, you can spend less time in sinking air, producing a considerable performance advantage in distance traveled over the ground vs altitude loss.
i think given two identical gliders (or trucks?) the lighter one will perform better. i think it'd gain more height in the thermal, and have a better glide path between.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Otherwise, I agree that vortex shedding would account for huge differences in velocity and pressure felt from passing trucks.
I think we can safely say: identical shapes in identical conditions = same aero effects regardless of mass.
Velocity is a vector. A speed of 30 mph north and a speed of 30 mph south are different.
Also a constant speed, say 30 mph on a turn or curve is an acceleration.
With regards to impact of mass, I agree that if everything else is identical, mass is irrevelant.
Both vehicles going around the same radius turn at the same speed will be accelerating and different mass means forces on the vehicles will be different.
Second order: ride heights will be different. response to buffeting will be different. etc. Whether these produce a MEASURABLE difference is another matter entirely.
Cheers
Greg Locock
The loaded radius of the tires would change also contributing to the difference in the ride height of the 'box' so the undercarriage air currents would be ever so slightly different making again an almost negligible difference.
The exhaust flow from the engine and the engine cooling flows would be different, for what ever minor effects those would have on the aerodynamics of the 'box'.
My vote is that there is no real world difference but a stimulating discussion none the less.
rmw
However, I'm not aware of any such effect on a truck. For this to be happening, there would have to be a wind-induced oscillation of the truck, and I've never noticed or heard of anyone else noticing such an effect. Trucks are often rough-riding, but that is due to ground effects, not air-induced vibration. You may get occasional vibrations in a tarp or tie-down, but I think this would be imperceptible in the overall wake of the truck.
http://w
TTFN
rmw
Agree that if they are identical in just being the 'same make & model' then one say empty and the other up at max load there would in practice be slight differences.
If the turbulence included shedding vortices, then the body of the higher mass truck could oscillate slower, so the vortex streets would be different.
the OP aked would the mass of a body affect it's drag. i guess we've identified a bunch of parameters that need to be included under "identical" that are not immediately obvious (ie ride height, roll stiffness and inertia, ...)
Guess that's why at uni they always said to state your assumptions!
