preheats in AHUs
preheats in AHUs
I am having problems with preheats in AHUs. Inside each AHU is a heating coil (Brasch)and an ultrasonic humidifier. The distance between the heating coil and the humidifier is approx 8". The unit pulls air from the outside across the heating coils to the humidifier to the cooling coil. Some coils are glowing red, sagging, and breaking. Does anyone have experience with this configuration. I would like to rule out airflow as a problem.
RE: preheats in AHUs
