Sketch dimensions
Sketch dimensions
Okay, I must be missing something obvious here. I go to edit my sketch and all the dimensions i put on it are not showing up. If I choose "edit parameters" from the part nav while out of the sketch, I see all my dims as expressions so I know they are there. I just can't see them when i go back into the sketch. What am I doing wrong or what aren't I doing?
Thanks!!!
Thanks!!!
RE: Sketch dimensions
NX3 here.
Justin Ackley
Designer
Glad it worked.
Justin Ackley
Designer
Note that for NX 6 we've gone one step further and provided an even more interesting scheme to make editing an existing sketch easier and more controllable. For NX 6 you can now explicitly declare which dimensions that you would like to be visible at ALL times, even when not in the Sketch editor. One of the purposes for this capability was to support the PMI tools where you annotate your 3D model instead of placing dimension on views of a drawing. But we've also added the ability to select and edit these sketch dimensions without having to actually open the sketch editor.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Justin Ackley
Designer
Bob Snead
Designer
Northropgrumman.com
I think you already posted this separately, which was the appropriate thing to do as this question has nothing much to do with the sketching thread. So I've answered in the other post.
Hudson
