split hopkinson pressure bar
im currently doing FEM analysis on split hopkinson pressure bar compression testing using abaqus. Below is some problem that im facing now:-
1. i do not know how to apply a nonuniform velocity on the striker bar.
2. The elastic wave i generated on the input bar does not contain reflected wave.
RE: split hopkinson pressure bar
If you mean non-uniform velocity with respects to location on a model, you will likely need to employ a subroutine - I understand this is using DISP (this method can also be used to create a time-based + location based non-uniform input).
Hope this helps
Thanks for your reply and opinion.
