Datumpoint tabel on drawing
Is there a nice methode to display they information of the datumpoint-tabel on a drawing. (parametric should be nice, but not neccesary).
I have looked in repeat region in tables but i don't see it.
I have made a model which is controled by datum points and i like to have the XYZ on the drawing in a tabel. (preferable parametric for controling and changings)
With regards
Rutger
RE: Datumpoint tabel on drawing
If you are created with Offset coordinate method,Go and check the info of the point and use its x , y, z dim id to create a table in drawing.If you are good in excell  you can edit those id's and import as .tbl file in drawing.
   Point created with any other method also you can check its id and build a table using excel and import/convert to *.tbl file to drawing.(it's parametric)
You can build a table with a "Hole Chart" for datum points, but I have yet to find out how you determine which points it uses, as it seems to just pick up all on the drawing, although you can then delete the rows/columns out the table you don't want.
Jon
