Gear Sets Materials
Gear Sets Materials
Steel roller cams with integral distributor gears, it is always recomended to use a lesser hardness distributor gear. So what difference is there in various gear sets in say any manual transmission, and for that matter any planetary gear set? And then move to the hypoid gears in a rear end. I was always under the impression that all gears in a transmission were the same materials and same hardness, they seem to live just fine. So what is the deal with distributer gearing? Is it more of a lubrication issue?
RE: Gear Sets Materials
Mike Halloran
Pembroke Pines, FL, USA
with gears however, you have two careful mating surfaces, and simly using a softer material will not help - it will wear faster alright, but when worn, you would still have to change both gears.
different materials are sometimes used (a resin based gear and a steel pinion) but in those cases lower running noise is the aim, not easy overhaul.
another point to remember is that all automotive transmissions are designed for a specific time span - and that all the gears available should total the total life expectancy of the vehicle. that also means that for example the backward gear has a design life of say only about an hour at full load - and that is sufficient for the gearbox to last say about 300000 km - since you do not go backwards a long distance and certainly not at maximum torque. in the same transmission the highest gear will last a lot longer under maximum torque conditions, since the car builder knows that it will be used that way.
there is a difference between typical automotive gears and industrial gears in this respect - industrial gears are usually designed for prolonged use (20 or more years at the rated torque) and this is reflected in the dimensions of industrial gears compared to automotive designs.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
As for transmission gears or rear end gears, they are made from different materials, use different lubricants (sometimes), and have different heat treatments. The automotive business is very cost conscious. The engineers at the automotive OEMs spend a lot of time and effort to get the optimum performance from the lowest cost component. They would not hesitate to use a different alloy and heat treatment for each gear in a transmission if it would save money.
As a mechanical engineer working in aerospace, I'm always amazed that an auto company can build and sell something as complex and reliable as modern automobile for the price that they do. It's truly impressive.
grins.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Nowadays its massive overhead that raises costs.
Thats generally so that they can afford to stay in business and continue to pay their employees.
Sheesh, it capitalism.
