serch not working.
serch not working.
serch not working.
I try to use the search before I ask any questions and end up coming back with no results. Am I using the search function wrong, is there a specific way of using it. Frankly I have tried holding my tong every which way I know how. The question I was trying to look up was where can I find a site and direction on making macros.
RE: serch not working.
Search seems to be working for me.
1) Click the Search button on the gray menu bar (2nd button), not the Google Search.
2) Type "creating macros" in the Keywords field.
3) Ensure Scope is enabled for "SolidWorks 3D CAD products only"
4) Ensure Use is enabled for "Exact Phrase".
5) Ensure Area is enabled for "Forums".
6) Ensure Fields is enabled for "Full Text".
7) Ensure When is enabled for "Any Date".
8) click Search button at the bottom of the page.
You should get 4 threads listed.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
MadMango,
Thank you, I have looked at this form over a thousand times and never noticed that Search. A star for you.
Bradley
SolidWorks Pro 2008 x64 SP1.1
PDM Works, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
