Hole Wizard
Hole Wizard
Is anybody else annoyed by the fact that when using the Hole Wizard that it defaults to placing a point when changing to locating the positions. Not that big of a deal but it just creates an extra step at the minimum to either delete the extra point or place it when doing multiple locations. At the worst it places a hole on a part when I don't need it and I forget about it until later when I look at the part and wonder what that extra hole is doing there....
RE: Hole Wizard
You have a great handle name!
One way to avoid this is to not to have a face preselected when using the hole wizard.
Personally, I am OK with the hole wizard, but the reality is that when I teach SWX in college and at the local VAR most students end up creating 2 holes instead of one.
I encourage you to submit an enhancement request to improve the hole wizard.
Perhaps others may want to throw a few ideas around on how to improve it?
cheers,
RE: Hole Wizard
RE: Hole Wizard
Bradley
SolidWorks Pro 2008 x64 SP1.1
PDM Works, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
RE: Hole Wizard
RE: Hole Wizard
In my opinion, preselection of a face is almost always the proper way to begin. Unless this has changed for 2008, if you don't preselect a face the hole location sketch is a 3D sketch rather than a 2D sketch on the face. 90% of the time or more, all the holes in a given hole wizard feature are going to be in one planar face. Any construction geometry required to properly constrain the hole locations should be in the 2D hole location sketch of the hole wizard feature. All too often I see users create a sketch with construction geometry to that defines hole locations prior to beginning the hole wizard. They then define the HW options, and then place 3D sketch points coincident with the points they created in the previous sketch. This causes an extra, unneccessary sketch feature floating out in the design tree by itself. Alternately, creating construction geometry in a 3D sketch has its own difficulties, as all entities must be constrained in three dimensions rather than two. Also, to add or remove a hole the user must edit both the hole location sketch and the hole wizard feature. I have submitted an ER to allow pre-creation of a hole location sketch. That would allow the user to create the hole location sketch with all its construction geometry, etc., then click the hole wizard button to define HW options. Every sketch point in the pre-created sketch would then be used to create a hole. I've tried to find a way in the API to make a hole wizard feature reference a different or pre-defined hole location sketch, but to no avail.
Sorry, long day for me too.
RE: Hole Wizard
-Dustin
Professional Engineer
Certified SolidWorks Professional
RE: Hole Wizard
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
RE: Hole Wizard
RE: Hole Wizard
When changing to the Position tab, you usually need to place dimensions to constrain the point, so all you need do is select the Dimension icon. This will automatically de-select the Point icon and you can start dimensioning.
RE: Hole Wizard
RE: Hole Wizard
RE: Hole Wizard
When you select to positions tab and it goes right into a point... simply RMB and select "Select" in the RMB menu.
Quick and easy to exit that cmd. Does not seem like a nusiance to me, because I have been doing this since HW came out years ago.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
RE: Hole Wizard
So why is a 3D sketch created when you do not pre-select a face? If you select a 2D face there should be a 2D sketch created "n'est pas?"
(ER request)
I second Handleman's ER to have the hole wizard be able to use a pre-defined sketch.
I would also add that if a 2D face is selected a 2D sketch should be created (even if the face was not pre-selected).
And get ready for this... if the face is rectangular a vertical and horizontal dimension should automatically appear to locate the hole... if the face is round it should automatically try to constrain it concentrically.
Your ideas are welcome, maybe after we through a few ideas around we can all submit ERs and improve the hole wizard (and then have a few beers).
RE: Hole Wizard
I don't think this should change. Its much easier to associate 2D with flat face selection and not picking a face for 3D selection.
Pre-defined sketch would be fine if you so choose, but should not be required to make a 2D sketch for your holes.
The Dimension thing IMO is not needed... That's like the initial comment about the point icon being started when you select Positions. You want to place the holes before you dimension them. Having it go to the point icon is better the then Dimension icon. As for what type of Dimension would vary between the types of Dimensions you need. Some people use Ordinate over Horizontal and vertical. You have to consider everyone's way of designing and not just yours.
The only improvement (ER) I see is being able to use a sketch that was added prior to starting the HW, but should not be require to use the HW.
RE: Hole Wizard
You’re absolutely right about this one. There is no reason that the 2d hole should not be put in when you click a surface. At the end of this post I will add my ER to the hole wizard. A star for you.
Bradley
