BTEX Monitor for Water Effluent
Trying to locate a reliable BTEX Analyzer / Monitor for a Petrochem water effluent stream. Range of 0 to 20 PPM is desirable.
The instrument will be located outdoors and requires NRTL Approval (ie UL, FM, or cCSAus) for Class 1 Div 2 Group C,D.
Any experience out there?
RE: BTEX Monitor for Water Effluent
h
You probably are aware that it is difficult to monitor oil because the oil will stick and/or coat most materials (including the sampling tubing). And that is why most sampling for reporting is done with batch samples for precise oil analyses.
Dual capability for BTEX analysis would be a bonus.
Thank you.
Unless you count naphthalene, none of the PAH are soluble beyond about 1-10 ppm, so what you'll be looking for at 100 ppm is free product or particulates containing these species. I presume you're regulated on PAHs well below 10 ppm.
