caterpillar digital regulator for generator
i see last week a caterpillar gen set, with a digital regulator ( it gots a display) does somebody know where i could find information about this regulator.... i mean some data sheet and specially some manual.
RE: caterpillar digital regulator for generator
Mike Halloran
Pembroke Pines, FL, USA
Do you mean the Electronic Modular Control Panel?
http://www.cat.com/cda/layout?m=41442&x=7#cpna
The EMCP is prominent while the regulator is often hidden behind bolted metal panels.
respectfully
Is your question still actual?
I think that the regulator you have seen is a DVR (Stands for Digital Voltage Regulator). If required I might be able to help you with some documentation.
