FORTRAN Program for searching files
Can any one help with some examples of programs coded to open text files, search them for some criteria, extract that data and dump into another text file?
Thanks!
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
RE: FORTRAN Program for searching files
Why Fortran?
There's an old general-purpose file parser program called FileParse written by Dead Pig Software.  They apparently ceased operation in 2000, but their program is still floating around in cyberspace.  It's a bit touchy, but will parse large text files.
TTFN
IRstuff - Fortran is what we have, though I suppose we have C++ and others along with it, Fortran is what I vaguely remember most of.
Admittedly I'm past my years of experience with this, hence my reason for posting, but I'd like to learn and if that means new language that's fine, just give me a tip and I'll track it down.
Qshake
pipe
Q,
I was just trying to point out that writing your own parser seems hardly necessary if someone already has one written.
TTFN
Thank you both.
Q
Qshake
pipe
Here's a simple example program.  It opens an input file. Reads each line of the file. Searches each line for the string, "Member Area".  If it finds it, it assumes a real number is on the line after "Member Area" (nothing else on the line after that).  It reads the Area value and writes it to another output file.  This is very simple, but... I think it shows the basic technique.  Once you read each line of your input file into a character string, you can play with the data in that string all you want.  Note, I just typed this in on the fly.  I've not tried to compile it to check for any minor typo's or other errors on my part.
Dan  smile
www.dtware.com
CHARACTER(132) ::  inFname = 'MyInputFile'
CHARACTER(132) :: outFname = 'MyOutputFile'
CHARACTER(132) :: str        ! character buffer
INTEGER        :: i, n
OPEN(12,file=inFname)
OPEN(13,file=outFname)
n = 0
DO
   Read(1,'(a)',end=10) str
   i = Index(str,'Member Area')
   IF( i/=0 )THEN
       n = n + 1
       Read(str(i+11:),'(f100.0)') area
       Write(13,'(a,i5,f12.4)') 'Member #', n, area
   END IF
END DO
10 Continue
CLOSE(12)
CLOSE(13)
END
