Balancing grades ISO 1940 vs API 610
please explain the relationship between ISO balance grades and grades specified in API 610 (such as 4W/N,4W/N etc W - mass of rotor, N- RPM).
In API 610 it mentioned as a note that 4W/N is equivalent to ISO 1940 Gr 1.0. Also that the grades mentioned in API are mid values of the range of the equivalent ISO grade.
Please clarify How should one interpret the above?
RE: Balancing grades ISO 1940 vs API 610
ISO permisable imbalance for balance grade G would be:
Uper = G M/Omega - M mass of rotor Omega - rad/sec (rad/time)
Uper = M e_per Omega/Omega - e_per = unbalance eccentricitgy
Uper_oz-in in oz-in = W lb 16 oz/lb 1 in/25.4 mm 60 sec/min/(N rpm 2 pi rad/rev) === or
U_oz-in = 6.0153 W/N - W in lbs N in rpm
API = 4W/N or equivalently
G_API = 4/6.0153 = 0.665
So, a balance grade G=1 does not quite meet API.
Bill
SHOULD BE
Uper_oz-in = 6.0153 G W/N - W in lbs N in rpm
With G being the ISO balance grade.
Bill
page 8 has a chart showing various balance grades for a 1000 lb rotor from ~500 to 7000 rpm.
Just looking at that chart on a Suday afternoon I'd say 4W/N is equivalent to ISO 1940 Gr 0.7ish.
