REFERENCE FOR DESIGN FOR BOX GIRDERS
Hi
I am in need of some good reference book on design of steel box girders.I specifically need the moment of inertia requirements for diaphragms
at the point of eccentric loading where torsional moment and a vertical load is applied to only one web(like from cantilever platforms attached to one web only).Any help would be highly appreciated.
Thanking you in advance for your help.
RE: REFERENCE FOR DESIGN FOR BOX GIRDERS
Dik
The best shot here is one of the AISC Design of Steel Highway Bridges Handbook. In it they have design examples of steel box girders. While the analysis is done by computer, most of the design components are shown by hand for clarity.
As I recall there is a box available on the design of box girders...just don't recall the author or date, but I know it is from the 70s.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Qshake
Is this steel box girder composite with a concrete deck?
VOD
http://br
With boxes torsional warping stresses should be looked at, the provided manual states that if less than 10% of long. bend. stress there is no need to consider it.
HTH
VOD
overhead cranes where drive platforms are directly attached to one web.Voyageofdiscovery which manual are you referring to?
The "manual" I refer to is the "AASHTO-LRFD DESIGN EXAMPLE HORIZONTALLY CURVED STEEL BOX GIRDER BRIDGE". This is obviously specific to bridge design.
http:
CRS - Can't remember $#!+
