Autodesk Grading Objects
I like using grading objects in Land Desktop, the only thing is once in a while I get a strange line that shoots down to nowhere and messes up my calculations. I checked all of the vertexes for the correct elevation, and looked to see if there was a grip on the end but there isn't. It's always on an inside corner of grading object. If I move the grips in the area around, I can usually get rid of it, unforunately this means somewhat distorting my grading footprint a bit.
Why does this happen? How can it be avoided/recconciled?
RE: Autodesk Grading Objects
