Impact test excemption curve for SA-350-LF2
Which impact test excemption curve SA-350-LF2 belongs to in UCS-66,2007 ASME Section VIII?The notes for the figure imply that forgings not listed would have curve B as applicable.
Is this correct for SA-350-LF2??
Hiren
Hiren
RE: Impact test excemption curve for SA-350-LF2
Yes, see Notes (2) and (3) in UCS-66. Material furnished under SA 350 is produced to a fine grain practice and is normalized or normalized and tempered or quenched and tempered.
Then according to Fig UCS 66(Edition 2007 page 173 Sec Viii Div 1) note (2) and Note(3)(b),Should not the SA-350 be under Curve C instead of Curve B,as SA-350 is produced to a fine grain practice and is normalized or normalized and tempered or quenched and tempered?
Mike
Second, regarding the impact curves and material, Curve B is applicable. If you read Note (2) in (b) of Figure UCS-66, there is specific reference to material product forms; "all pipe, fittings, forgings and tubing which are not listed for curves C and D below", the Note that might be confusing you is 3 (b) for Curve C material.
Mike
