Insert Design Tables in drawings
I'd like to insert a design table into a drawing but Insert--> Tables --> Design Table... is greyed out. I've searched this forum and Solidworks help but with no luck. Any help would be much appreciated. Thanks.
RE: Insert Design Tables in drawings
The design table will display in the drawing exactly as it appears in the part/assembly document.
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
