Higher Heat Application Shoulder Screw
Hi All-
I'm using a 304 Stainless Steel shoulder screw that's threaded into a 304 stainless steel plate. The application can reach about 180° Celsius steady state, and will change from there to STP about 6 times a day.
The shoulder screw needs to be removed once a week for cleaning, and the problem is that the shoulder screw is extremely difficult to un-thread after cooling. I am wondering if there is another material I can use for this shoulder screw that may give me better results.
Any input or suggestion is appreciated, and if any more information is necessary, please let me know!
V
Mechanical Engineer
"When I am working on a problem, I do not think of beauty, but when I've finished, if the solution is not beautiful, I know it is wrong."
- R. Buckminster Fuller
RE: Higher Heat Application Shoulder Screw
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
V
Mechanical Engineer
Cory
V
Mechanical Engineer
http://www.cartech.com
Mike Halloran
Pembroke Pines, FL, USA
V
Mechanical Engineer
Okay, now I'm thinking of something more sophisticated. A fixed cylindrical sleeve, with an internally engaged plug-in head/flange retained by a mechanism like a ball-lock pin or a Cleco sheet metal tool.
Mike Halloran
This opens up a new question... If anyone has any ideas of ways to create this joint, other than a thread, please feel free to comment. I will post up a rough picture tomorrow morning.
Thanks again all.
V
Mechanical Engineer
Right now, Item 1 is about .2" thick, and can't get any thicker. There will be 4 Item 3's connected to an actuator that force item 1 upwards. There isn't a lot of force seen on these connections, so a completely rigid setup is not necessary. If anyone has any ideas/thoughts, I certainly welcome them.
Thanks again.
V
Mechanical Engineer
