how do you make a decal?
I am trying to make a decal out of a jpeg. and am not successful at all. Does anyone know where I might find a tutorial on how to, or good instruction?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: how do you make a decal?
Decals are available only when PhotoWorks is added in.
Click New Decal (PhotoWorks toolbar) or PhotoWorks, Decal.
In the Decals PropertyManager, under Image file path, browse to an image of type .bmp, .gif, .jpg, .png, .rgb, .tga, .tif, .wmf, or .p2d, then click Open.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Unless you're applying the image to the part directly (such as you would with screening or pad printing) I suggest making another part that acts as a label. The label will have the decal applied to it as a part. Then wherever the label is, you have your decal.
Jeff Mowry
www.industrialdesignhaus.com
What did you dream? It's all right--we told you what to dream.
--Pink Floyd, Welcome to the Machine
Make the label an actual part with the decal applied. The label part can be a transparent surface or extrude, if required.
