double arrows 2008
double arrows 2008
double arrows 2008
Does anyone know how to get double arrows to show up on horizontal or vertical dimensions? I'm on a section view (side view of diameter)that I want to spec out a diameter with a dimension.
RE: double arrows 2008
As in 'Foreshortened'? With the drawing opened, Tools->Options->Document Properties->Foreshortened Diameter.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Tools - Options - Document Properties - Foreshortened Diameter, then select the "double arrow" or "break w/single arrow"
or do you mean as in .....
Right clicking the radius or diameter dimension and select Display as linear?
Remember...
       "If you don't use your head,            idea
                   your going to have to use your feet."
Use "multi-Jog leader" (under annotation Toolbar or pull down).
Select initial location and select last location. RMB (Right mouse button) and select "End Leader".
Tada! double arrow.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
