Steel Panel Foundations
Any opinions on this system?
Do you agree that it's the first "green" foundation for a basement?
http://www.steelpanelfoundations.com/
RE: Steel Panel Foundations
I would wonder though:
1. How much soil pressure can the system resist?, and
2. If the three boards installed on the outside offer any ICBO rated shear resistance, or must it come from plywood on the inside?
Mike McCann
McCann Engineering
The chemicals in a wood PWF foundation prevent it from being burned safely in the future. Also, I really believe there is consumer resistance out there to PWF. Steel would never support mold, whereas I've seen mold eventually grow on wet treated wood.
DenverKev - If you want green(er) go for the tire-and-rammed-earth wall popularized in part by Dennis Weaver and his mansion in Ridgway or somewhere over there. (Google earthship + tire.) I say this only half in jest. Friends of mine got the Boulder County bldg inspectors to accept it for their earth-sheltered house in Nederland. (I'm assuming from your handle that you live in Denver CO. Otherwise, you might not know the reputation of Boulder County inspectors. I'm told they give
Steel studs are killers on insulation. They can reduce an R19 insulation (theorhetical "pink-not green" lab test) to an effective R11 wall. The heavier gage studs could have even worse actual thermal performance.
Cement does require energy, but is generally relatively local. Aggregates are also local and do not represent a large amount of energy. Deliverly and distant transportation associated with iron ores, processing and delivery of finished steel products are very big factors when looking at the big picture.
A different approach - As backward as they may be in some areas, China has abandoned both wood and brick as "green" materials in favor of of concrete masonry because of land preservation, continued use of arible soil, pollution, energy to produce, transportation and constructability of an energy efficient residential structure. This started abo 10 years ago, and the old inefficient polluting brick plants are being phased out to preserve the land and soil. - Not a small job since China uses 525,000,000,000 brick each year(500 per person) and they now import wood when necessary to preserve good soil. I don't think ethanol has a good future in a country with over 1,000,000,000 people.
Everyone has their own idea of the factors in what is "green". The concept of building out of waste materials is good on a small scale until people realize the waste has value if there is a demand. - I remember when fly ash was a waste product and people paid to have it hauled away and dumped.
Dick
When steel studs are insulated in this manner (on the outside), there's no thermal performance penalty.
It pretty easy to assume that a majority of new homes will be replaced within 60-200 years given the way homes typically become obsolete.
A concrete foundation can easily last that long, but what a costly pain to haul away. Steel panels will easily pay for their own trip to the scrap yard. If the hot clay soils just happen to damage the foundation, the concrete version is impossible to R & R cost effectively. Steel studs would be relatively easy to sister up and rejuvenate.
If neither style of foundation degrades, either one could be re-used under the new building. That would be the greenest outcome.
